Morph goes crazy after pose
echristopherclarkechristopherclark Posts: 276
edited February 2021 in Daz Studio Discussion
Anyone have any idea what might be going on here? I'm using a morph I loaded in with Morph Loader Pro. It looks fine in the standard pose, but once I apply a pose to the figure things like this start happening to the fingers. Arms can also be twisted as if they were a dish rag you were trying to dry out. And the face goes horrific when certain expressions are applied.
Post edited by echristopherclark on
  • echristopherclarkechristopherclark Posts: 276
    Figured it out. I was following the WP Guru's instructions here
    but needed to take an additional step found here in RenderHub's video
    Basically, I needed to fix the skeleton, as described in the second video.
    Just wanted to leave this here, in case someone else needs it some day.
  • It looks as if you need to Adjust Rigging to Shape (Edit>Figure>Rigging), then link the adjustements to the morph via ERC Freeze (Parametrs pane right-clicked to Edit Mode, then right-click your morph>ERC Freeze - assuming you haven't already done an ERC Freeze; if you have you need to find the cotnroller in the Property Hierarchy and right-click>ERC Bake or you will trigger a Duplicate Formilae error).
  • Thanks, Richard. Yes, that looks like what I needed to do.
