Select root instead of child node in viewport
I have updated DAZ, and some of my settings are reverted to default. I remember there was a tricky to find option to select figure first, instead of selected bone.
  • vukiolvukiol Posts: 66
    in tool settings, at the bottom, but, isnt root first by default?
  • Vukiol is right: you're describing default behavior. While you do get to see the names of the individual parts when you hover over a figure it will still select the whole figure by default as soon as you click on it. So if this behaves different for you then it would appear as if some of your settings / changes were retained.
    Maybe a useful tip: F4 (Save layout as...). Although the name implies that you only save your layout (so: the way in which you organized the UI (panes and such)) the reality is that this method also includes your actions, toolbars and the (pulldown) menus. Which means that if some settings do get reverted back to default then you can easily change back by selecting your own workspace layout again. See also: "Window (so: the menu) => Workspace => Select layout...".
