Adding to Cart…
For those reporting the image upload issues, I know they are looking into it still. Sorry for any inconvenience. Hopefully it will be functioning for you very soon. That said, Ive made note of the browsers and additional details you all have given. TY
Yes. There is a section underneath where the images in that Album are that will say "Unpublished" The image should show there. (Though atm it may or may not be working as they have been updating various things)
I will be putting together some tutorials on everything though I want to wait till they push through some of these initial fixes.
This is also something I ran into, because I almost always open links in a new tab if I want to look at them after I've finished the page I'm on. I tried to do that several times and didn't realize it wasn't letting me until I went back to look at the tabs I'd opened and found that it had just opened the gallery thumbnail in a new tab, not the actual page.
Sorry I missed your question initially. To answer you, I believe (though I am not 100% certain) that Popular will be based on most popular of all time. Trending will be the most popular images over a specified time (much the way the store functions)
So as an example Popular will show the most popular images in the gallery to date in order starting with most popular. Trending will show you those images that are most popular within say this past week or two weeks (A specified time frame of Daz 3D's choosing)
ATM the images may seem similar because there was no gallery technically yesterday. (Also it may be that the hamsters need some munchies for motivation hehe - I'll keep an eye on it and see what it does and if it still seems similar we can report that so they can take a peek)
BRB I'm going to record one of the videos for you all real quick (on general gallery browsing and functionality). I'm going to wait to cover uploading and albums etc as I know they are working on those things still atm. Give me a bit here and Ill be back
I get "The page failed to save" without any hint to what could be the issue.
Cool, thank you for the explanation!
Thank you! I don't see that in my gallery album yet, but I'll give it some time for them to work things out.
I can save my entry but cannot crop the thumbnail (seems to work but then only shows the original crop) and then I get "Page failed to publish" on both Chrome (Windows 10) and Edge
In the galleries, there is still my old Artist name! Is this changeable to AlfRaMusic?
I meant seeing the links on already existing images, not when uploading new ones now. However I did find the links - down the bottom of page (missed them as I’m on iPad cos computer has been dead the last month or so). But on that note, it seems some links to products used on my existing images seem to have dropped off. For instance, I KNOW I linked the hair, the character, the dress and the shaders used on dress on one of my images, but the only product link showing now is for the shaders. Is this a known thing, that existing images are missing some of the previously linked items?
Ann, just as a FYI, on that image @bytescapes linked, I only see 6 ‘products used’. The three you’re seeing that I’m not, are the 3 daz originals, interestingly enough. I’m on iPad, using safari, if that helps. And on your image, I see 4 linked products.
me Too!!!!!!!!!!
"I get "The page failed to save" without any hint to what could be the issue.
me Too!!!!!!!!!!"
-I have found a solution:
Just create a new album, your new picture will be published there.-
DAZ_ann0314 - could possibly help with troubleshooting. :-)
Hi in the new Gallery do you have to wait for it to be approved before it will be published, just tried to post two images but they failed, yet they are in my gallery? tia
I can create a new album - but renaming it doesn't hold (It's always "New Album") and I cannot use it to save or publish an image.
Horrible. Catagories, Tags, and Daz 3D Items Used is clunky. Sometimes you can't delete a mistake. Images do not save, preview, or even post. Errors on Publish. The UX/UI is downright horrible and in no way show signs of usability research.
1 Step
My Albums (push it)
2 Step
Edit (push it)
3 Step
New Album (push it)
Now you can see "Choose or Drag new Image for a new page ..... (use it) (published your image)
4 Step
Rename your new Galleriealbum
Greetings ADC
For new users, yes, but I thought existing users were automatically OK.
I didn't had a problem uploading my images, though I did notice a few things with the new gallery I didn't quite like.
1. As @tdc said above, if one made a mistake and put in the wrong category there was no way to either change it or delete it without cancelling the whole thing and starting over
2. I also found it very very annoying that the category list remains even when you start writing in the boxes for Tags or Items Used.
3. Something I would like to have when I go to the gallery, is the possibility to choose wether to land on the Trending, Popular or Newest page. As it is now we automatically end up on Trending, while it is easy to go from there to Newest it is still a little bit annoying not being able to choose.
Other than those three points (as of right now atleast ;P ) I am quite happy with the new gallery :)
4. Edited cause I just remembered I forgot to add something that is quite annoying as well. The text just goes on and on in one line, without respecting the seperations I have made for it. Which makes it outright Horrible when having wrote out a longish story to the render
This worked, @DAZ_ann0314
Lots of steps, but it might help out the team to know that this method posts the image, when all others don't.
That did the trick! Thanks for that!
Just keep getting "Page Failed to Publish" wion't show in my gallery iether tia
Since my question about being able to delete mistaken tags or categories from an image was ignored, I am flagging it for deletion.
In the 'Items Used' section of a gallery page I only see the products that I haven't purchased. It thus makes sense that the creator of that gallery page doesn't see anything in the 'Items Used' section as they already own all of those items. What doesn't make sense is Daz's assumption that the only use for the Gallery is to sell us stuff.
I suspect that this problem is related to the Store's search function's refusal to show us things we already own. Both the Store and the Gallery should give us a way to override that feature.
That seems to be affecting several users, though others have been able to upload. It isn't an approval thing - it simply isn't completing the upload process.
Thanks, I've passed that observation on.
Since my question about why the 4th image at the top of our gallery page is cropped on the right-hand side was ignored, I am flagging it for deletion.
Here is what I found that works for me
1) Click on Galleries
2) Click on My Albums (Do NOT click on Post image)
3) Select either root gallery or another album and click on Edit (Again do NOT click on Post Image)
4) Once you click on edit there should be an unpublished items section with a box to add an image. Add your image to that box.
5) When your image has finished adding to that box, click on it
6) Add your page title and whatever description you want Then click on Save and then on Publish
Your image page should now appear in your selected gallery
Note: If I use the Post image links I see in steps 2 or 3 then my image will not publish properly
This worked for me! Thanks.
However I still cannot crop / edit the thumbnail - forced to use the (poor) default framing
EDIT
Well - it worked for ONE picture - but back to fails again after that!
