Adding to Cart…
Carrara native render
mostly anything glows lights
9 of them
but bounding box, object glow, shadowbuffer
and one ring shaped light
the transmapped fusion "particles" (rotatable mesh lump of shapes) would have taken eternity to render
so I replaced them with actual Carrara metaball particles whih were much faster and cooler
Probably the final version of this scene. I'd been hoping to get the lighting a little better, but because of all the trees and such, sky light and indirect lighting was taking a ridiculously long time to render on my quad core system (hoping to upgrade to a Ryzen 3950 XT soon.) No postwork other than slight bit of sharpening and a vignette around the edge.
free Smithsonian model
flyaround
@magaremoto That last test of Howies scenes you did, the one with the side on version of the girl works really well. Congrats!
Also the one by the lake with the side on man and AO turned up is another winner!
Fantastic work, All!!! Loving these renders!
Headwax, those composited images are Awesome! Very well done!
Magaremoto, Three HW scenes in one scene? Yikes! I'm loving your research. Your images always drive me!
Firelight, Firelight? The Firelight? Hi! I'm Dartanbeck. Love that image! That Daz 3D logo on the side looks FanTastic! Hey, if I could get a copy of that History of Carrara from you, I'd really appreciate it! I miss it not being up anymore. Could I post it for nostalgia sake?
Diomede, Rock On! Cool renders!
Wendy, Awesome stuff, Girl! I love that Smithsonian piece! Thanks again for turning me on to that link!!! :) Love that interior scene on the previous page as well!
M.Cody, Oh my! A human child in an Elven sanctuary? Darn Unicorns will never learn!!! Great image!
I can't comment on everything today, but I'm really loving all of these great renders and ideas! Keep up the excellent work everyone!
thx sci fi funk, tryng to get the most by using AO and irradiance map caching; thx for your tuts too
keep up the good work
thx DB, with a lot of ram and maybe a good mobo you can easily load scenes like maple meadows, stoney creek and valle alpina all together as in my test. Carrara never disappoint you if you treat it well :)
please in your pipeline consider to use 3delight too, its renders can turn out similar to carrara native but with DS power tools. By the way, it's me or DS 4.15 exports fbx into carrara perfectly?
2 carrara-like 3delight renders attached
playing with haunted mansion
Thanks Man! I'll try that after work!!! Both of them!
Awesome renders!
Very Nice! It's been a while since I went into that amazing place!
i'm hearing munsters theme song LOL
Hi everyone, love seeing the things other people create with this program, keep it up. I couldn't exactly remember my lighting set up for my previous render and couldn't find the car file but I did still have the obj models I used so I tried to recreate it, it is a little different but it is also a lot simpler lighting set up. A hdri, one distant and seven spots. Global illumination and full indirect switched on. A few mistakes in this render but I only noticed them after I did the final and after two hours of waiting for it to finish I let them go, it is only a re hash to try and get the effect again
Dartenbeck, thanks for the comments, do you mean some of my earlier youtube videos I did? I remember you did comment on some of them.
UE4 Supermarket
Carrara Octane
needed to rename materials because of name truncate issue on save
took a few hours to do the hundreds
Well done for persisting. I was going to do the same, but have been held up with other 3d issues.
It looks good, but can I make a suggestion? I see there are a ton of spotlights in the model. If they are all set to share the same shader and that is an emitter you'll get a more dynamic lighting look and it won't take much longer to render as they are sharing and it's just effectvely one emitter.
This will be my first attempt at lighting, plus I will look to highlight any signs that might be neon, like the bakery letters with a very low range on the emitter. Although that adds to the emitter load on the scene, the low range will make very little extra work for the render.
p.s. Slightly off topic but having seen what unreal can do with high quality shaders, I'm excited to see how they compare:- Carrara (Octane) vs Unreal (internal shaders). Bring it on!
yeah need to create shading domains for that, I used glow maps,
will take as long again
Just a proof of concept for an idea of an animation I plan to work on.
Very cool!
Anything Glows is growing on me
with shadow buffer using vertex and object glow color it can render very fast
i animated the flame textures both glow and diffuse too
seeing if the gallery links work ... super stuff that!
I see the Gallery is Back.
Here is an image I did last year but did not have time to post.
Uses Dart's Badlands and the Light Assault Vehicle which does not work properly in Carrara. The back Ramp will not work. It just deforms the Mesh.
I put the ramp down in Studio then export it and it imports fine with the ramp down.
Love the Red Gas Cans Which Just Say Shoot Me.
Reminds Me of Bouncing around in the back of one of them in Afghanistan in 03.
Gallery is back but currently is pretty hard to post an image... I did manage it by having to create a new album as adding to current ones didn't work.
great image @chickenman .. but what is that black bit that stands out in the back of the unit on the rh side.. should it be there?
Biggie
Wendy, that's Awesome!!!
Stezza, Super indeed! Great Render!
Chickman, Excellent! Just don't be around when they shoot those cans!!!
Misty, Adorable!!! :)
Don't worry about the noise from the 25 MM cannons there is already som much noise going on that you are deafend if you dont have earplugs in already.
But it is only a temorary loss, But to many times and it be comes perminant.
working on haunted mansion shader sets to try submitting to pc club. want to open the door for new carrara content in the pc club. frreebie of the week or something.
the first one is Carrara
others DAZ studio and iClone6
Early WIP for kitbashing Ming the Merciless.
The Daz G2M figure with a mixture of Lee 6, Michael 6, The Wizard, and Emaciated full body morphs.
Carrara hair applied directly to model to get the facial hair.
I read that the 80s version of Flash Gordon was getting a 'potentially offensive' warning because of Ming.
https://www.bbc.com/news/entertainment-arts-55409194
