Content Library Problems. Why Daz? Why?
ancichancich Posts: 26
I have been using Daz 4.6 since it came out and today I got a nasty surprise. I click on Content Library, then click on Categories, and ALL of the categories are GONE! I tried refreshing and that did nothing.
What is the point of carefully categorizing your props and models if the program mysteriously trashes your efforts? I feel like I can no longer trust this program.
  • fixmypcmikefixmypcmike Posts: 19,709
    edited July 2014
    Are you using Valentina CMS or PostgreSQL CMS?
    EDIT: Sounds like Valentina, since you were able to click on Categories. Have you exported user data before?
    Post edited by fixmypcmike on
  • ancichancich Posts: 26
    edited July 2014
    I am simply using whatever came with Daz 4.6. I shouldn't have to be a database expert for it to remember its shit.
    I have not exported user data. When I installed Daz, the content categories were all pre-made and they held the default models, props, etc that comes with daz4.6. As I installed other models, I would have to add those manually. But today.... poof.... all gone.
    Post edited by ancich on
    First try this method:
    1) Shut down DS
    2) Go to the Start Menu > Programs > DAZ 3D > DAZ Content Management Service > Start CMS
    3) Restart DS
    4) If the categories are back, go to the options menu (the icon in the upper corner of the Content Library with 4 horizontal lines) > Content DB Maintenance > Export User Data. It will take a while if you have a lot of manually-categorized content. That way you'll have a backup if the database gets corrupted.
  • deleted userdeleted user Posts: 1,204
    edited July 2014
    1) Shut down DS
    3) Restart DS
    Tried this method a hundred times. It only lasts about 15 minutes before it shuts down again.
    I've tried everything in the book... Never worked for me. I gave up on the CMS a long time ago...
    Useless application if you ask me.
    Post edited by deleted user on
  • FishtalesFishtales Posts: 6,223
    Check your firewall isn't blocking access to the port the CMS uses. I couldn't see the Smart Content either until I set my firewall to 'learn' so it flagged every access. It flagged the DAZ CMS a few times but after I added the blocked files to the trusted zone it has been working ever since.
    1) Shut down DS
    3) Restart DS
    AWESOME! IT WORKED!
    If I need to read in the manually-categorized content, do I choose 're-import Metadata'?
    1) Shut down DS
    3) Restart DS
    AWESOME! IT WORKED!
    Yes, that's right.
    Thank you so much for your help!
  • mark128mark128 Posts: 1,033
    If you have not upgraded to PostgreSQL CMS, which it sounds like you have not, you can go to the directory:
    Program Files -> DAZ -> Content Management Service -> vlogs
    There should be a lot of log files in that directory. Look a few of the most recent ones. See if there are any messages that look like errors.
  • Richard HaseltineRichard Haseltine Posts: 109,424
    edited July 2014
    Edited as I'd missed the recent posts.
