Animate2 walk cycle glitch?
DekeDeke Posts: 1,636
edited July 2014 in Art Studio
I'm using the stock walk cycle in Animate2 and there is a bit of a glitch. A the start of each forward cycle, the left foot slips backward. Anyone else have this problem? Or a solution?
Post edited by Deke on
  • DekeDeke Posts: 1,636
    Just bumping this? Any help out there? The figure's planted foot slips backward on the first frame of every cycle. I've tried moving the Z axis manually for that frame in the Keymate window, but it doesn't help. And it happens whether I stack separate forward cycles one against the other, or just have one that is extended in length. And it happens whether I'm in packed or sparse layout. Grrrr.
  • chorsechorse Posts: 163
    edited July 2014
    What figure are you using and what aniBlock? Do you have the latest version of aniMate 2 and DS? I have no issue using V4 and "forward (1 cycle)" aniBlock.
    Full version AniMate 2, DS 4.6.3.52 64bit, win 8.1 64.
    Post edited by chorse on
    Using Dad 4.6.3.50 on a mac. Applying that forward (1 cycle) to a Genesis 2 figure. I think it's Michael 4. I'm rendering something now and because there's no background rendering, I can't go in and confirm the precise figure.
    The original aniBlocks were made for M4/V4 figures. There is probably a bone mismatch issue. You could try burning the aniBlock to DS keyframes, make the necessary adjustment on the DS timeline and the burn it back as a G2M aniBlock. You could also create your own M4 to G2M utility aniBlock using a separate timeline. Save the a M4 to G2M aniBlock then use it when using legacy aniBlocks with G2M. I sometimes use the V3-V4 aniBlock on Genesis with ok results.
    Thanks. I'll give those things a shot.
  • BC RiceBC Rice Posts: 591
    Not sure what software you're using, but this might assist in either program -
    http://www.youtube.com/watch?v=RJDR1SsUOYs
