DForce clothing problem
Hello! I hope you can help me, I have a problem with dForce clothes, it is as if it got under the chest and I do not know how to fix that, I also attach a photo of how the breasts look below, I do not know if it is normal to see So, I hope you can help me fix this problem
It may well not be dynamic in the bodice - either there may be a separate surface group with Dynamic Strength set to 0, or there may be a weight map applied (you'd probably need to add a dForce Weight Node to check that). Which outfit is it?
is Young Minto's clothing, I don't remember the first one, but I have this problem with almost all dforce clothing that is somewhat tight..
