Install shaders
I have downloaded some shaders for Carrara. I have 8,5 for the Mac. I can't figure out how to get them into my shaders browser. How is this done?
Thanks.
Thanks.
Hi ric
You mast create a folder named for example new shader or free shader and in Carrara on the inferior bar clik on "add/folder menu" (is the last button on your wrigt hand). Then choose "add folde"r and select your folder...
I use this way in Win but must be the same in Mac
Hi,
on Mac, you normally must have all your Presets in the Document folder.
You could create new folders to organise your objects or shaders
(see attachment)
And you have also Presets in Carrara
Application > Daz 3D > Carrara8.5 64-bits > Carrara
Right clic on Carrara to open it and see all the content ands find shaders
Thanks. I see the folder. I'll give it a try.
