Victoria 4 morphs not loading
TY3DArt
I am not sure why, but my V4 morphs don't load anymore when I select the character. I have to manually add the morphs to the shaping parameters section. If anyone can help me so I can fix this, or reset it to load the morphs. Thank you!
Wow, glad I'm not the only one to have this happening. It has been happening to me as well...I had a custom figure I would just load that had all my morphs loaded and she no longer works properly. I wasn't sure if it was the latest Daz upgrade or the database upgrade or what, but I've had to do it manually as well...I'll try making a custom save once again to see if it works again, but it was annoying the heck out of me this weekend too.
Guess we can try reinstalling V4 and all the morphs again to see if that works, but hoping somebody has a better solution!
i was reading on another forum, people are having problems with her blink morph.
just thought i'd mention it in case the powers are reading this. :)
is this with existing files or a "fresh" load of V4
there was a problem a while back where V4 an M4 in existing scenes would load and you had to reinject the morph files to make them function. It seemed as though it cleared up but with the latest build (4.6.3.50) it's back for me with scenes that I saved in version 4.6 and builds above (so far)
For me it is an existing file...I had a base V4 character with all the injects and morphs I liked saved and just called her up and applied character morphs, but when I called her up this weekend (after taking a month away from Daz) she loaded without anything and had to re-inject everything...
did you have PerfectV4 morphs injected into this figure?
I had a bug report a while back and it no longer exists so I cant see what ever happened, but it might be time to open a new bug.
Yes, it was a PerfectV4 figure I had saved (along with a few other morphs)...
Where did you open your report....with X&M?
first with bug tracker which there were several others collaborating until Daz took that entire system off line, then I filed a 2nd report with Xen Desk which was not collaborative.
It's gone from my account on Zen Desk, no record of it.
