Adding to Cart…
Okay. I'll give that a try.
It works.
Thank you so very much. Selecting the garment, then the parameters then the FIT TO MODE and AUTOFOLLOW TRANSFORMS does the trick.
What's weird though is now I can't actually select the figure in the scene window in order to do posing. There's a little red circle instead of the arrow cursor.
But still.............this is serious progress thanks to your suggestion.
Again thank you, Richard.
It works.
Unfortunately the hair doesn't work either. It ends up as a beard. Redirect and Autofollow Transforms doesn't seem to help.
Hair used to work though. It really did.
I think I need a holiday from Daz. Maybe kill every customized character I've made, delete everything and start again from scratch.
(fixed qotes)
