Lost content categories and can't restore it
VolvoB10MVolvoB10M Posts: 135
edited January 2021 in Daz Studio Discussion
I tried following a support instruction to save character selection (figure, hair, surface and clothing) but in trying it I found this did not work and has broken the DAZ Studio. At first I found the Smart Content had lost all the categories and there did not seem to be a way to restore them, all the content seemed to be dumped in to one thing showing under all products. I have since completely uninstalled and reinstalled DAZ Studio and all content in the assets list but now nothing at all appears in the Smart Content except the last purchase which is greyed out and locked and only appears in the "All" bottom tab. How do I restore this to as it was before?
Post edited by VolvoB10M on
  • cm152335cm152335 Posts: 421
    edited January 2021
    in case your smart content is empty
    run "content db maintenace" and "re import metadata"
    the re import feature read all installed  ".dsx" found in ":runtime/support" folders of any library
    Post edited by cm152335 on
  • VolvoB10MVolvoB10M Posts: 135
    edited January 2021
    I wasn't referring to the search there is nothing in the bar on the left, it is the same if the search bar is empty. Everything is only in the same product, as well as that the last purchase will not show as installed in DAZ Studio despite being installed.
    "Smart" (not) content, categories, products, etc. all rely on the information inside the database to be correct, which quite often is not the case.
    Follow the advice of @cm152335
    edited January 2021
    I have managed to get the content list back but I have noticed there are a few products missing that were installed before and show as installed in DC, how do I get these back?
    edited January 2021
    Thanks for the support, it is now solved, I Imported Metadata then reset the content library again and they are all there although they don't automatically install anymore, is there a way to change this?
