pwGhost to Genesis
BrianG61BrianG61 Posts: 45
Hello,
I'm trying to apply pwGhost to Michael 5/Genesis, but it doesn't seem to work. If I apply it to a simple primitive it does work. Can anyone help.
Brian
    Can you post results of the render, so we can see what is happening?
    One thing to note is that because Genesis has a lot of different surfaces, when applying a new shader you'll want to select the surface you want to apply it to in the surfaces tab.
