Reality 4 Won't start/ Can't start
Like the tittle said, Can't start Reality plugin from Daz studio, Tried on 4.9, 4.12, 4.15.
3 threads on Reality offcial forum with similar isssue no answer from Paolo.
What is going on with this plugin?
What OS are you running?
Tested on two Windows 10 PCs, one with 1909 the other 20H2. I think I may found the issue. seem to be nvidia driver issue.
Both PC uses the newest driver, I rolled back the 1909 to older driver pre-30 series drivers and Reality able to start. Not sure if i can test it on 20H2 cause it have 30 series card.
What can be done? wait for working driver to work with 30 series card?
Found the issue, It seems when updating to the new driver it also has a newer version of OpenCL.dll Ver 2.2.8.0. What I found is the old driver has an older version of the dll ver 2.2.5.0. I copied the dll and reinstalled the new driver and copied the dll on to System32 to replace the newer version. Now Reality Works again! Maybe this will work for some.
