Need more 8.1 content
alienarea
in The Commons
In my opinion Genesis 8.1 and Victoria 8.1 are great products. Now I need more content:
- Genesis 8.1 face and body morphs
- a tanned skin without freckles
- some makeup, fingernails and lip color options
- new, better hair
All G8 content works fine on G8.1 including all the morphs, skin, nails and makeup... The body mesh hasn’t changed at all, just the face and UV.
why would hair be 8.1 content, not like they introduced a new hair system with 8.1
Genesis 8.1 can already use Genesis 8 face and body morphs, it doesn't need new ones.
What it does need is a converter like X-Transfer to convert G8 expressions to G8.1.. SInce right not the bulk of G8 expressions do not work with G8.1.. The funny thing is that using X-Transferred G3 expressions work totally fine..
G8 expressions do work on G8.1
Using only G8 expressions with the new V8.1.
Daz has done an amazing job on the new Genesis 8.1 update IMHO. I totally agree with the OP, we definitely need more content.
Well after doing a bit of digging and reading another thread, I found that with the changes to Genesis 8.1.. They changed the folder naming for expressions, and why Genesis 8 expressions do not work correctly as most folks would expect.. So it is true that not all Genesis 8 expressions work as they should more so the PA made ones..
When you remove the expression placeholders that G8.1F installs into Genesis 8.1 female, DAZ 3D morph folders, all the expressions do start working, also the PA made ones that are calling those expressions which were made non functioning by the placeholders.
Thank you for that bit of info, who knew that removing the Base Pose Head folder (not me by the way) would fix the problem, the issue though is that it was not obvious.. lol In the end though, those who do not know this, will be wondering WTH is going on and would get a bit miffed..
But OT yeah would love to see more content for 8.1 and a lot of fixes for scripts and so on to work with Genesis 8.1..
