Adding to Cart…
thanks.
aww extract along blank
Blank means: You can define your own shortcuts, there is no predefined shortcut.
Update: "Keyboard Shortcuts Reference for Carrara 8 / 8.5" in PDF format (now more printer-friendly).
You can find the download at CC under Publication > http://carraracafe.com/downloads/
Image link broken for the tutorial "Adjusting amplitude, scaling etc.." http://docs.daz3d.com/doku.php/public/software/carrara/8_5/userguide/animating/tutorials/graph_editor_box/start
See after the title Adjusting amplitude the missing image is "adjust_amplitude_1_before_anotatedb.png", the image exist but have bad link.
any info on the inner workings of the wizards?
i re org'd my ca library, now the landscape wizard and shader wizard lost >.<
try reset preferences
is it impossible to do the Remove unused shaders and objects with 1 key? mebbe a function key.
and a function key to rotate selected instance 180 degrees?
that would save so much time.
