Daz 3d dont see content folder
calaopiecalaopie Posts: 215
edited July 2014 in Daz Studio Discussion
Why daz 3d can not see the contents of the file content folder?
Install all the downloaded add-ons to the basic folder c: user/daz3/my libery ect . It daz seen, but I had very little space on drive C So I cut the whole folder daz 3d the c: users / my dokumenty/daz3d and pasted on another drive where I had more space.
In daz 3d showed a path to this folder. Daz sees the folder and subfolders content but does not show the pictures. Simply can not do anything.
Sorry 4 my poor english.
Post edited by calaopie on
    Can you post a screenshot of your Content Library pane showing the DAZ Studio Formats and Poser Formats that you have listed. Similar to what you have already posted, only showing more of the left hand side of the Content Library?
    Can you also post a screenshot of what you have listed in Edit > Preferences > Content Library > Content Directory Manager showing the expanded list of what paths you have.
  • calaopiecalaopie Posts: 215
    edited July 2014
    Daz Studio formats - My libery - there's nothing there
    Poser formats
    In D:/Nowy folder (19) i istal all content.
    I cut earlier Daz3D entire folder from c: users / user / my documents/daz3 to save time on installation. Now, when I pasted it to c: users / user / my docs / ect everything works fine, but I do not have c drive space: (.
    1440 x 900 - 240K
    1440 x 900 - 218K
    1440 x 900 - 210K
    You've set up your new content location as "Other Import Formats" but not as "DAZ Studio Formats" or "Poser Formats". It should be set up the same in the other two as well.
    edited July 2014
    I set it as the screenshot and finally work: D Thanks for your help.
    1440 x 900 - 281K
    Just one possible gotcha — you said you've moved all your content, including the free stuff that comes with D|S, onto your other drive? If so, you don't need the two locations at "C:/Users/". This might be a problem because one of them is the first defined content location under DAZ Studio Formats. This is a special setting because, whenever you load a Poser-format item into your scene and save it, the object will be converted into D|S-compatible data and saved into a /data/ folder in that first content location. This means that the more scenes and old Poser items you save, the more files will be saved back onto your C: drive, which is what you wanted to avoid in the first place.
    Check your old content location to see if any new /data/ files have been saved (copy them to the same place in the new content location if there is) then remove those "C:/Users/" paths from your content settings.
  • JaderailJaderail Posts: 0
    This is what your Paths should look like and only this. This will use just the Drive D: folders as everything. Nothing is needed beyond this... Not even for Other Formats...
    525 x 514 - 198K
