Tilable shader for Daz Studio 1 and Daz Studio 2 - With independent Bump/Displacemt Tiling
mCasualmCasual Posts: 4,607
edited July 2012 in Freebies
download : https://sites.google.com/site/mcasualsdazscripts2/mcjglossy
well i know it's a very small tribe, but somewhere out there , they are still using Daz Studio 1.8 and 2.3
As long as you render in software (3Delight ) mode and use the proper shader, DS1 and DS2 can render tiled textures
and here's a proper shader
Image below was rendered in DS 1.8
in 2012
oh my Bob !
later that day i discovered that DS2.3 too didnt have tiling, and the new shader works for DS 2.3 too, how lucky is that!
the version posted july 2 2012 has independent controls for Bump/Displacement tiling
and the version posted july 3rd has reflection, refraction and is completed yay hooray woo hoo
Post edited by mCasual on
  • nitehawk_ltdnitehawk_ltd Posts: 387
    edited July 2012
    Looks nice.
    Quick question...
    How do you tile textures in DS 2.3?
    I don't see tile on the surface tab.
    Making custom tex mats is a pain.
    Do I need to run a script like this one?
    Thanks!
    Post edited by nitehawk_ltd on
  • mCasualmCasual Posts: 4,607
    Looks nice.
    Quick question...
    Thanks!
    Well how about that i thought DS2.3 had tiling but it doesnt
    the good news is, the new shader i posted works with DS 2.3 too !
    ( i have Ds 1, 2, 3, 4 on the same pc )
    This image rendered in DS2.3, 10x10 tiling
    800 x 600 - 132K
    edited July 2012
    Thanks for your quick answer!
    I'll have to try this.
    /EDIT
    Another Quick question..
    Does this work for bump mats also?
    Thanks again
    edited July 2012
    nope, because the displacement / bumpmap part of the shader was left as-is.
    a while ago (2010) i did make some tests with displacement shaders and i should take time to finish and package it someday
    there' the water in that video is an animated shader
    http://www.youtube.com/watch?v=PKGKv_E8Lo8&list=UUaZUbnoQhRMoSb_ShW81ONw&index=5&feature=plcp
    edited July 2012
    /EDIT
    Thanks again
    actually i tried my hand at a tilable displacement shader
    and if all goes well i'll publish it later today
    on the left you can see the image
    on the right, a tiling bump map
    next i'll see what it needs to work for displacement maps
    oops actually this seems to be the displacement effect, not the bump
    800 x 600 - 71K
    edited July 2012
    /EDIT
    Thanks again
    well the new shader for DS 1 and 2 should come out tomorrow
    there will be the usual texture tiling
    plus independant Bump/Displacement tiling
    in the image below, the diffuse color map is tiled 3x2
    and the Displacement map is tiled 30x20
    this opens possibilities that single tiling control lacked
    2nd image is the displacement map used
    800 x 600 - 253K
    256 x 256 - 3K
    800 x 600 - 217K
    news ~ update ~ news ~ update ~ news ~ update ~ news ~ update ~ news ~ update ~
    so this morning the shader was updated and now has independent Tiling control for bump/displacement
    so you could have a diffuse map with the word spalding
    and a tiled displacement map for the dimples
    later today i should post another version with reflectivity functionnal
    as shown here
    600 x 600 - 152K
    edited July 2012
    things are looking up
    ( wasnt that the title of a famous flutist's vinyl album? )
    the final shader may be posted today and i'll try to add a version for DS 3 & 4
    "there is no try" -- Yoda
    ( yes it's the title of the Moe Koffman i bought when i was something like 18! man oh man ) :)
    ----->>> http://www.youtube.com/watch?v=tBoNw_TPSHA
    600 x 600 - 270K
    ~~ News ~~ ~~ News ~~ ~~ News ~~ ~~ News ~~ ~~ News ~~ ~~ News ~~
    tis ready
    here's the new logo
    600 x 600 - 100K
    ~~ news ~~ ~~ news ~~ ~~ news ~~ ~~ news ~~ ~~ news ~~
    if you downloaded the shader before you read this post,
    it's probably better to re-download it,
    because at one point i posted a version that didnt work
    ( i humbly apologize , feel secure in knowing that i consider myself the abject shadow of a yellow dog's flea and unforgivable, ok maybe not that humbly :) )
    so in theory if the universe cooperates, the shader will work fine :)
    latest render in DS 1.8
    600 x 600 - 256K
    edited July 2012
    WOW... Just Wow.
    All the more reason to stick with DAZ 2.3.
    Thanks
    Quick question.. Where did you get the outfit your model is wearing?
    Thanks again.
    WOW... Just Wow.
    Thanks
    Thanks again.
    i made it, a mix of a leotard and a quipao/cheongsam
    it's a spinoff of trying to reproduce the light and skin in this ad:
    low cut cheongsam
    but i'm so far from the mark !!
    i may post the leotard and dress for free someday but not soon.
    the dress (chongsam) in the image below was eventually converted into a dynamic dress and used in some videos
    presenting mcjTeleBlender
    more mcjTeleBlender results
    800 x 450 - 69K
    800 x 450 - 71K
    WOW... Just Wow.
    Thanks
    Thanks again.
    actually i should post the leotard over here : http://www.daz3d.com/forums/discussion/3718/ tomorrow
    I've been playing with this shader and I love it.
    I know that this is a "glossy shader", but is there a way to make it less glossy?
    In the attached render, my entry in the Aug. freebie contest, I used the shader on the ground plane.
    As you can see under the bikes, the shadow is washed out by how glossy the ground is.
    And this is after I turned the glossiness down to 65%.
    I know that I'm doing something wrong, any suggestions?
    Thanks
    Gerry
    1286 x 1284 - 687K
    Thanks
    Gerry
    sorry !@ i was forgetting to reply to this post
    i'll get to it right now :)
    edited August 2012
    Thanks
    Gerry
    simply turn "specular strength" down to 0%
    also make sure not reflection map is applied to the reflection channel of the surface, and that the reflection strength is at 0
    note that if you apply a "voronoi" texture like the one shown in the second image to the bump map,you get a sort'of good beach sand
    i made the voronoi texture using blender, it's free. That texture is non tilable but, if you google-ima-search for 'voronoi' you can find seamless/tilable ones.
    4th image is the same texture but sharper
    800 x 800 - 293K
    800 x 800 - 394K
    800 x 800 - 290K
    800 x 800 - 67K
  • ThatGuyThatGuy Posts: 797
    edited August 2012
    HI! So when do you think DS 4 version might be available? Are there any plans to make it also for DS 3 and 4?
    Post edited by ThatGuy on
    He made this script to give users of DS 1.7 - DS2.3 some features that are already present in DS 3 & DS 4.
    So you don't need it. Check the surfaces tab, you'll find it all there.
    sorry i didnt reply before, but it seems the daz forum skips emailing me about new posts :)
    i will probably make a ds3, ds4 ds4.5 version
    the interesting feature of this shader which is not present in DS3+ is the separate tiling of the bump maps
    also, down the road, a shader to make oceans the way Carrara (i think) does it in the free edition, by adding sinewaves
    i experimented with that too-long ago :) as seen on YT (oh my) http://www.youtube.com/watch?v=PKGKv_E8Lo8
    1277 x 699 - 87K
  • MJ007MJ007 Posts: 1,716
    Awesome thread. Just what i what i was looking for.
    -MJ
