V4.2 and M4 Morphs++, Muscle Morphs, etc. Not Displaying in Smart Content; Not Injecting...
Hello,
I am having issues with various morphs on Michael 4 and Victoria 4.2.
I am installing via the .zip folders, and dragging the folders in the zipped "content" folder to the default "My Library" folder, and merging the folders.
The Genesis morphs and figure appear fine, and function fine, however, V4.2 and M4 morphs don't appear in Smart Content, and when i search for them in the content library, and try to inject them, no new shaping options or parameters are displayed.
The morph packages are also not visible when re-importing meta data to smart content.
Does anyone have any advice? I've been away from DAZ Studio for roughly a year, and the BitRock installers are gone, and i have no intention of using an install manager, and documentation seems suppressed and/or hard to find, as does support.
Any assistance potentially appreciated, thank you!
Generation 4 items are under Poser Format Content in the Content Library pane.
The Other thing to be sure of is that your Content folder you are using is mapped as both a DAZ Studio format folder path and a Poser Format path. If not the Poser content is not seen by DAZ Studio at all...
I can find them alright, however the morphs do not seem to be injecting, either. Also, some gen4 content displays in smart content just fine, materials and models. Morphs, however, do not seem to be displayed in smart content, currently, and are not injecting through the content library...
Suggestions?
If you did not Install the V4 M4 figures with DIM or the older EXE installer they have never had the exp Bat file run. This needs to be done or the figures have zero expansion morph channels to inject morphs too. Those files are found in the Content folder in RunTime>Libraries>!Daz and are the DzCreateExPFiles-V4.bat and soon on. Once the bat files run morphs should inject properly.
The morphs in question are seemingly "seen" by the content library, just not Smart Content. They also are not listed when re-importing meta data (suggesting maybe morphs++ for v4.2 and m4 don't have meta data?), and the morphs look as though they are being injected, however, no new parameters or shaping options become available after.
Any further suggestions?
They don't have metadata. Have you run the DzCreateExPFiles-V4.bat and DzCreateExPFiles-M4.bat as Jaderail mentioned? Note that after running these the new morph channels will only be available on a fresh V4 or M4 loaded from the Poser Formats > Figures > DAZ People folder, not any V4 or M4 in saved scenes.
