Program crash after hiting render button.
i cant do any render, here is log file, programe crash every time i hit the render button also iray preview render is very slow. i just reinstall the latest version before posting this still the issue after some time
2021-01-12 13:42:59.280 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(359): Iray [WARNING] - API:DATABASE ::   1.0   API    db   warn : Transaction is released without being committed or aborted. Automatically aborting.
i74790 16gb 2070 super
  • What driver version? What security software?
    Nvidia Studio Driver 460.89
    for security its just windows defender
  • I think others have had trouble with that driver - it may be worth trying another, slightly older version.
  • Frown-emojiFrown-emoji Posts: 121
    Same here:
    2021-07-29 19:31:41.805 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(359): Iray [WARNING] - API:DATABASE ::   1.0   API    db   warn : Transaction is released without being committed or aborted. Automatically aborting.'
    NVIDIA GeForce RTX 3080
    AMD Ryzen 5 5600X
    32GB
    Gigabyte B550 AORUS PRO AC
    Nvidia Studio Driver 471.41
  • DartanbeckDartanbeck Posts: 21,988
    I'm not sure if this had anything to do with it, but  was having the same problem, but fortunately I saved the scene just before, so I was able to try some things.
    I was using the Dire Wolf with dForce fur in an animation.
    When I turned Off the ground in Iray Environment tab, I was able to render the full sequence, but without the shadow caster.
    Again, not sure if that is what actually did it, but there's that.
