dForce hair and large file sizes
dForce hair simulations are resulting in a ridiculously large save size. What's going on here? I'm working with Magnolia hair for the first time, and saving it to a file after a simulation has been performed results in a file size that is beyond 1GB. That's the only difference with this scene and previous backup saves.
I can also save the file without any simulation data and the file size is normal too.
  • For each vertex in strand of the hair DS has to store the location - or for a Timeline simualtion, the locations. That is potentially a lot of data.
  • mtl1mtl1 Posts: 1,508
    Is there a way to cull frames of data except for the current frame? I'd like to be able to save the file at the final frame for rendering.
  • SevrinSevrin Posts: 6,313
    You could probably save the final shape of the hair as an OBJ and then apply that as a morph to the hair.
    Yes, this is what I ended up doing. Shame there isn't a way to export or save simulation data from a single frame... or even delete simulation/animation data from the timeline.
    Does freezing simulation not work?
