Apply Victoria 8 pro, female anatomical elements without using Vic8 materials?
Hey all, is tehre a way to use the V8 pro female genetalia but on the textures of the genesis 8 female model?
Since V8 will load with a slightly diff hue and value because the skin of V8 and G8 are slgihtly different
Or maybe are tehre other anatomical bits addons that fit better with the G8 model? (texture wise)
Post edited by Chohole on
There aren't any Victoria 8 Anatomical Elements - there is just the one set, included in most but not all adult Pro bundles, and they should work with any character that has a set of materials for them.
Do you mean use the gen textures without applying the genital addon? Yes you can do that in a paint program like photoshop by aligning, scaling and warping the gen texture onto the torso texture. You'll also want to do a hue or sample coloring tool to match them up. You'll also want to probably run a feathred eraser around the gen layer to remove any seems.
But there is better alternatives...just won't find them here on this site.
Right, and for the base genesis 8 model are there maps available for the anat elements?
I thought there were, but couldn't see any when I looked.
What better alternatives are there? that dont look like its "pieced on" like with the V8 pro anatomical elements onto the G8F
Look for characters that list "Anotomical Elements" under the materials options. Those are genital maps. Some characters that don't list them still have them but they aren't guarenteed to be there.
For example https://www.daz3d.com/alla-hd-for-genesis-8-female has them.
I don't think they are cool with me posting such links, You can always go in and model edit whatever you want in blenderr, or try using the "mesh grabber" and use it to grab some.....
If the figure/character you're using doesn't come with a texture for them, then you could get Skin Builder for Genesis 8 to solve the problem. It has an alternate UV set for the female genitals that uses the torso texture(s), and is seamless.
I think the other alternatives that have been mentioned can probably be found at Renderotica.
There are UV maps available that use torso textures for anatomical elements (GenTorso UV for G8F), although you will need a geometry shell to modify certain parts
there is another thread here on this forum, so it should be fine to link to that. CaymanStudios offer a tool (8even free) to make copying the Torso surfaces to the AEs. It's labelled for Genesis3 but fread the thread headline for yourself. There you go:
https://www.daz3d.com/forums/discussion/178186/torso-uvs-for-g3f-anatomical-elements-genesis-8-compatible
On another note, why not simply load the V8 UV set in general?
