Demon Horns for G8?
vonHobovonHobo Posts: 1,715
https://www.daz3d.com/damien-demon-for-genesis-3-male-s
Can the horns from this product be used on Genesis 8 Male?
I have the Universal Hornes for G8, but these horns look more like real demon horns. I was hoping I could just add them to G8 without using the Damien figure itself.
  • As I recall, they are "Anatomy", but not geografted like the pee-pee prop. (I cannot think of any horns that I have that are geografts. Maybe Rhino guy, perhaps...) They should load without much issue, almost like hair, especially if you swap the base figure ID.
    The head morph wouldn't work as easily because you'd need to transfer those between G3M and G8M.
  • vonHobovonHobo Posts: 1,715
    Thanks!
    How do I "swap the base figure ID." ?
  • The Blurst of TimesThe Blurst of Times Posts: 2,410
    edited January 2021
    Thanks!
    (Just talking from memory since I was rendering on my daz machine... but the render is done for now.)
    Load Damien Demon horns... then you'll want to Edit the "Scene Identification" for the horns, and change the "Preferred Base" figure from G3M to G8M.
    Then you can autofit to G8M.
    (This works for Genesis 3 to/from Genesis 8 due to the high degree of compatibility. Won't work the same between, say, M4 and Genesis 8.)
    Post edited by The Blurst of Times on
    Thanks!
    Wow! I never knew that. Thank you so much!
