Creating a daz3d tattoo
vvs021088
Hi!
How to achieve perfect tattoo joints?
it is almost impossible to customize manually.
especially difficult where the shoulders And elbows.
there the docking goes in an arc So you have to bend the drawing.
maybe there is some plugin for the program? Help solve the issue.
Please don't post parts of texture maps.
For the middle of the back an Iray Decal Node, if you are rendering in Iray, would be the obvious choice. Otherwise people use tools with 3D painting abilities - ZBrush, 3D Coat, Substance Painter - even Blender has some ability in this.
Yes thank you, I've already come to this myself, trying the program Substance Painter
in DS is named iRay Decal Node, but is necessary to create an opacity map for that task, in the past was doable with PNG for itself but actually transparent PNG files does not work anymore.
Substance Painter is great if you are using it as a complement of your workflow on a daily basis...or having money to spent for a yearly $219 USD.
