Parameter dials
sueyasueya Posts: 853
edited July 2014 in Poser Discussion
I have just opened up Poser 5 after not using it for a while
I can't get the parameter dials to show up properly. I can only see the Transform dial. How do I get the other dials to appear?
Post edited by sueya on
  • KeryaKerya Posts: 10,943
    Do you have something loaded that has more parameters?
    Because, if you have a prop it usually has only transform dials ...
  • sueyasueya Posts: 853
    edited July 2014
    No as you can see from the attachment I have only one figure in my scene.
    384 x 300 - 25K
  • WandWWandW Posts: 2,903
    Are there parameter dials in the Body Actor?
    I can only see the transform dials for the Body Actor
    502 x 405 - 37K
  • Richard HaseltineRichard Haseltine Posts: 109,458
    Have you tried scaling the Parameters panel up? Drag on the diagonal lines at bottom-right of the panel.
    Yes, the Parameters panel has been shrunk right down. Look at the % value, it has the bottom of the numbers shaved off, and the scroll bar at the right edge shows the view is scrolled right to the top of a long actual panel. All you can see there is a tiny shaving of it. Resize the panel and you'll be able to see the rest.
    Thanks for the advice. I have increased the size of the Parameters window and I can now see all the dials.
  • FightingwolfFightingwolf Posts: 50
    Wow. Poser 5? When ever possible upgrade to Poser Pro 2014 as soon as possible. If you can't do that then upgrade to any version higher than Poser 8.
    So many things have changed with Poser since Poser 5 and many of the things that were frustrating to do in Poser 5 are much easier to do now.
