Linday Long Wavy Hair Suddenly wont take texture presets
This hair has suddenly stopped taking the color changes provided with the item.
I redownloaded reinstalled and restarted and it will only take the texture it has on load up.
Promt says check Log. Log says:
Vertex Shader compiled successfully.
Fragment Shader:
Fragment Shader compiled successfully.
Linking Shader:
Shader Program successfully linked.
2021-01-02 11:45:24.937 Loaded image dFVH Blonde B.jpg
2021-01-02 11:45:25.160 Loaded image DFCLH2 Thin A-3-3.jpg
2021-01-02 11:45:25.394 Loaded image DFCLH2 Thin A-2-2.jpg
2021-01-02 11:45:25.729 Loaded image dFCW Hair A 02-2.jpg
2021-01-02 11:45:26.021 Loaded image dFCW Hair A 03-2.jpg
2021-01-02 11:45:26.303 Loaded image dFCW Hair A 04.jpg
2021-01-02 11:45:31.484 Invalid hierarchy for selected node(s) and "preset_hierarchical_material" type; no root(s) found.
2021-01-02 11:45:31.484 Error reading file, see log for more details.
2021-01-02 11:45:40.121 Invalid hierarchy for selected node(s) and "preset_hierarchical_material" type; no root(s) found.
2021-01-02 11:45:40.121 Error reading file, see log for more details.
Is the hair parented to the figure, and is it being used with the figure it was made for?
Yes. The other hair product made by the same vendor works fine when changing colors.
This one just stopped.
