what is a 'default SSS' mat?
Very noobie question but when you have a character I find you have the selection of the regular standard default mat and the 'default SSS' mat. What is a SSS mat and what is the difference between them?
    edited January 2021
    The default mat is probably the 3Delight default shader that does not have SSS (SubSurface Scattering). The other alternative is most likely the AoA SSS shader which is also a 3Delight shader with more advanced options, including Subsurface scattering. It could also be the OmUberSurface shader that also has SSS but it works a bit differently.
    Post edited by Sven Dullah on
  • ToobisToobis Posts: 993
    I see and why might one use this please?
    You mean SSS? It is a way of simulating the way light is absorbed and scattered when hitting a surface.
    SubSurface Scattering = SSS
    There are settings in the surfaces tab to increase or decrease the effect.
