Disappearing Mouse Pointer [SOLVED]
2»
  • AbnerKAbnerK Posts: 718
    My doctor has 40 years of experience but, that only means his mind is stuck in the past and his judgement clouded by years of prejudice. I changed doctors because he refused to accept there was anything wrong with me. Some actual tests proved I had several chronic problems for which I now get free prescriptions for. Free because in the UK if you have a congenial disorder you get free prescriptions.
    Being old is not synonymous with having all the evidence or being good at guessing which is NOT science.
  • OstadanOstadan Posts: 1,130
    I hope it is not rude to point out a typographical error, but I would _love_ to have a 'congenial disorder'.
  • Taoz said:
    you don't need to restart Studio just try to blindly navigate it to the viewport/camera selection tab and click there
    I can't seem to make this work... Am I meant to click within the active viewpoint?
    Try to find one of the controls in the Viewport like the View Selection dropdown (I think the others work too but this one does for sure) with the invisible cursor and then click - the controls will light up when you hower the cursor over them so you can see where it is.  That
    will make the cursor visible again.
    Thank goodness. I've been having this problem and now there is at least a workaround to it. I've long since given up on DAZ actually /fixing/ anything at all, so at least now it's a tad less frustrating to use.
  • gederixgederix Posts: 390
    Awesome, worked like a charm, thanks!
  • McGyverMcGyver Posts: 7,085
    I dunno... My mouse pointer used to disappear, so I just glued it to him...
  • davesodaveso Posts: 7,863
    here it is October 2021, and its still hasppening. twice tonight actually. so its not solved by any stretch
  • TaozTaoz Posts: 10,276
    It's been fixed in the latest public build.
    I'm using  4.15.0.30  is there another? nothing shows update in DIM
    That is the general release, and doesn't have the fix. It is in the Public Build (the beta) 4.15.1.72.
    edited October 2021
    Thanks Richard. At least now we know its coming and will live with it until the time its released official.
    Post edited by daveso on
  • Pantros2Pantros2 Posts: 103
    Easily recreatable in 4.16.0.3:  Click both mouse buttons while cursor is over the control with the four compass points by the rotation cube. Drag mouse slightly and the cursor will vanish.
    Get it back by going just above the rotation cube and dragging down perspective view to activate that menu. It can be tricky to get to that menu, but this will make the cursor visible again.
    Although 4.16.0.3 is later than the beta with the fix, the fix was not in fact moved across. It is still in the current Public Build from the 4.16.1.x branch.
  • Well since, after years, I finally got frustrated enough tonight to go look for a solution, instead of just saving, shutting down and starting again, and given that I am using 4.16.11.17 I guess that I am going to have to wait a little longer for the poroblem to go away.
  • Sorry 4.16.1.17.
  • kervalakervala Posts: 186
    Thank you so much, it worked for me :) I had this issue several times and I didn't find another solution than closing DAZ Studio :(
  • The dissappearing mouse pointer has come back sad
    I've seen it occasionally in recent DS versions, but it's rare that it happens, and it seems to behave a bit different than the "original version".  I'm using Mouse Without Borders, don't know if that has any negative or positive effect on the phenomena.
  • 3Diva3Diva Posts: 11,981
    This disappearing mouse pointer is a constant issue for me when trying to paint weight maps. It disappears every 30 seconds or so while trying to paint weight maps. I tried Wendy's solution but I have to keep trying to navigate to the camera selection tab every 30 seconds or so. I also tried the "Show location of pointer when I press the CTRL key" solution but that worked for about five minutes and then stopped working when I hit the CTRL key after that. Has anyone found a better fix for this? The mouse pointer disappearing every few seconds while trying to paint a weight map is driving me crazy.
  • frank0314frank0314 Posts: 14,736
    edited February 2025
    What GPU driver are you on? How much RAM do you have? What version of Daz Studio are you on?
    Post edited by frank0314 on
    Hi Frank! I have an NVIDIA GeForce GTX 1080 Ti, driver version 32.0.15.6614 - when I go to "update driver" it says I have the current driver. I have 16 GB RAM. I'm on Daz Studio 4.23.1.36 Publishing Build.
    Post edited by 3Diva on
