Daz Central Broke Daz Studio
dfurlong
UPDATE: Ok. I didn't realize the missing file is the apple renamed library issue and this is a known issue. I should have read before updating. Hopefully, Daz will get this fixed soon.
I opened Daz Studio this morning and it worked without issue. I installed Daz Central and now the only thing that opens when I click on Daz Studio in Central or the icon and all I get is the error posted below. I don't understand what is going on. Anyone else on Mac and Big Sur run into this?
I've uninstalled and reinstalled Central and Studio. I have tried to manually reinstall and it doesn't work and of course, the Install Manager is now broken, too.
Thank you for any help.
Process: DAZStudio [1870]
Path: /Applications/DAZ 3D/*/DAZStudio.app/Contents/MacOS/DAZStudio
Identifier: com.DAZ.DAZStudio
Version: 4.14.0.10 (4.14.0.10)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: DAZStudio [1870]
User ID: 501
Date/Time: 2020-12-30 14:03:08.398 -0600
OS Version: macOS 11.1 (20C69)
Report Version: 12
Bridge OS Version: 3.0 (14Y908)
Anonymous UUID: 5F46CAEC-463A-048F-EF11-EA7ED6E815A4
Time Awake Since Boot: 2300 seconds
System Integrity Protection: enabled
Crashed Thread: 0
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: DYLD, [0x1] Library missing
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
dyld: No shared cache present
Library not loaded: /usr/lib/libstdc++.6.dylib
Referenced from: /Applications/DAZ 3D/*/DAZStudio.app/Contents/MacOS/DAZStudio
Reason: image not found
Binary Images:
0x100000000 - 0x100002fff +com.DAZ.DAZStudio (4.14.0.10 - 4.14.0.10) <1B01D0F7-E12E-6372-B1E2-3526BB15C912> /Applications/DAZ 3D/*/DAZStudio.app/Contents/MacOS/DAZStudio
0x100006000 - 0x1028c6fff +libdzcore.dylib (1) <0984042F-7E52-6E4B-57ED-E5C6CD9C259E> /Applications/DAZ 3D/*/libdzcore.dylib
0x102f8b000 - 0x10323bfff +QtCore (4.8.7) <4CA3C606-A089-F187-979B-7B48C41EC059> /Applications/DAZ 3D/*/QtCore.framework/Versions/4/QtCore
0x1032cf000 - 0x103c99fff +QtGui (4.8.7) <83428699-BE40-1D52-E6DE-D119AFD0A1B1> /Applications/DAZ 3D/*/QtGui.framework/Versions/4/QtGui
0x7fff67be6000 - 0x7fff67c81fff dyld (832.7.1) <DEA51514-B4E8-3368-979B-89D0F8397ABC> /usr/lib/dyld
Model: MacBookPro13,3, BootROM 429.60.3.0.0, 4 processors, Quad-Core Intel Core i7, 2.9 GHz, 16 GB, SMC 2.38f11
Graphics: kHW_IntelHDGraphics530Item, Intel HD Graphics 530, spdisplays_builtin
Graphics: kHW_AMDRadeonPro460Item, AMD Radeon Pro 460, spdisplays_pcie_device, 4 GB
Memory Module: BANK 0/DIMM0, 8 GB, LPDDR3, 2133 MHz, 0x802C, 0x4D5435324C31473332443450472D30393320
Memory Module: BANK 1/DIMM0, 8 GB, LPDDR3, 2133 MHz, 0x802C, 0x4D5435324C31473332443450472D30393320
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x15A), Broadcom BCM43xx 1.0 (7.77.111.1 AirPortDriverBrcmNIC-1675.1)
Bluetooth: Version 8.0.2f9, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB 3.0 Bus
USB Device: Apple T1 Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 41.2
Lah-di-dah! Mac user not bothering to look at the pinned threads. https://www.daz3d.com/forums/discussion/451486/daz-studio-macos-big-sur-compatibility#latest
