single shader
Hi!!! I have a lot of objects, about one hundred, and all need the same shader... there is a way to apply one shader to all the items in the scene??? thank you!!!
If you delete all other shaders, the remaining one will be applied to all.... But literally ALL objects/domains in the scene must use that same shader....
You can also drag a box over multiple file names in the "Instances" tab, then go to the "General" tab and select the shader you want from the drop down arrow next to "shader".
