easy way to remove brows??
hi... community,
i have nearly all content for customize my models now but still looking for a simple way to remove and replace the eyebrows and lashes...
Eyebrow builder and eyelash builder dont work.. the brows get not replaced just overbrushed .. ?
I want light brows and light lashes !
Do i have to rework the skintextures themself??? i think the only option for me is now to go into the skin texture and remove the brows and lashes... but i dont know if it will look good after...especially because i use only gimp and have no photoshop .... is there any other way??
ok the problem with the lashes i have solved now.. i just lower opacity and used lash builder then.. but with brows its not possible because the brows are on the skin txture itself and not separate like the lashes ...
What can i do now?
I can't find a way to not make that sound badly, so be it :
you could use Gimp or photoshop or whatever image editor on the skin texture Or start with a skin without brows.
Sorry if I sound harsh :)
yes i already did it .. thanks , i just wonder why the brow textures are integrated into the skin and not just separated..it would make everything much much more easy also for ds newbies like me ... thanks so far
Because there was no separate Brow area on the older generation figures so the Brows were just painted on the textures, and that is still a normal practice as many users find the Brow section a bit fiddly to work with and get looking good in renders. I prefer to not use it if I do not wish too for example.
ah ok :-) ill create a skin with black and blonde brows then.. thanks for explanation and support so far . greets
