Phoebe HD - Big Face Morphs Problems!
I am getting big problems when trying to use face morphing on the Phoebe HD character,
I am trying to apply different expressions and almost every time the jaws sticks out of her face!
This cannot be good the problem does not appear on the original Victoria character.
Post edited by TalZac on
Trying to use this product on phoebe HD seems total impossible…
FangTastic for Genesis 2 Female(s
http://www.daz3d.com/fangtastic-for-genesis-2-female-s
I am getting very strange renders
Almost none of the expression works without the jaws sticking out of her mouth!
Every face morph is different and there is no way to make every expression work on every face morph.
Have you tried using the Jaw adjustments under Pose controls to help compensate?
I will try this now, thanks :)
Curiousity ... does that happen too with the
/People/Genesis 2 Female/Characters/FWArt/Phoebe/!Morphs/Vampire Snarl Apply.duf
Thanks!! This worked, i did not know of this function. Thanks Again!
No I do not think so, but most of the standard smile and other settings will show this problem also...
Hello
To avoid problems like that, FangTastic has a special morph called "Lower Back" (wich is located at the same place as all the FangTastic morphs (Actor >Head>Fantasy SciFi)
You can use it anytime you need, on any character if you just need the jaw to go back at its normal position.
This morph replaces the Genesis 2 basic jaw movement.
Feel free to ask if you need any more help.
C.
Hello
C.
I can not find this, is it in the shaping section? I can find how to modify the teeth but not "lower back"?
Found it now, searched for it with the filter in the paramters section :)
Thanks!
It seems to be working now :) Thanks all for you help! Now I have learnt something new! :)
Happy you could fix your problem with this specific head morph.
Just for info, if anyones needs it again, it's here :
