There is something wrong with G8Fs' anatomical elements in 4.14?
iSeeThisiSeeThis Posts: 560
edited December 2020 in The Commons
I've just noted that when I load female gen, there is something wrong right away. I've tried to change UV but nothing better. Is there anything wrong or there is something wrong only for me?
Mod Edit :- Image removed
Post edited by Chohole on
  • felisfelis Posts: 6,522
    I have tried both latest build and latest beta - both are working.
    Have you Geometry Editor active?
    Per the PA, Ensley is supposed to be an underage character, and iirc there's something in studio's innerworkings that somehow prevents the gens from being attached to minors based on certain criteria.
    Post edited by Lissa_xyz on
  • iSeeThisiSeeThis Posts: 560
    Nope. So sure.
    I'm not even aware that Ensley is a child :D But I've tried Victoria 8 and others, the result is the same. I've just known about the problem just because I am to use it. Thank you very much.
    Nope. So sure.
    Try to select the Universal Tool and see if that changes anything.
    • BJ Ensley is not marked as a Teen figure on it's shop page, but if one looks carefully she comes without anatomical element textures/materials.
    • Teen typed figures can use the anatomical elements supplied by DAZ or other sources, but as the example of BJ Ensley shows, the DAZ often can't be used due to lack of materials/textures, while 3rd party versions usually have means to "build" the needed materials/textures in a different way
    • all this as nothing to do with the OP's problem.
    Can't deliver a solution to OP's problem, but maybe deleting/re-installing the anatomical elements might help? Seems to me as if the geoshell isn't applied properly..
    @iseethis Since this happens with any character, are you positive it's actually fit to the character and not just parented? @maikdecker Blue stated the character was underage in a forum post. https://www.daz3d.com/forums/discussion/comment/5517986/#Comment_5517986
    Okay. Now I've learnt how stupid I am. It was on Mesh Grabber mode (I just sure I wasn't on Geometry Editor but really forgot there is another of same kind). I thank you all anyway!
    Post edited by iSeeThis on
    I've tried to apply golden place from rendo to some characters but it didn't work anyway. And it's good to know that DAZ tries to make us have a good attitude about there products :D
    Golden palace works on every character I have used it on.
    Which could (!) lead to me returning the figure, if "grown up" materials - like nipples - aren't supplies with a figure that is stated as being "teen" in the shop... as DAZ wants the forum to be seen as "not DAZ official" any posts here are nice, but not "official". So when DAZ doesn't want to sell teen figures with mature materials/textures, mark them on their shop pages, DAZ
