I need help!
After adding many products to my DAZ library, some of my characters have changed their shape and I can't do anything about it. I think the problem is corrupted "data" that got into the library with one of the products. I need to find and delete these files. But I don't know how to find them. My library is several hundred gigabytes. Help solve this problem!
Post edited by AStayneLite on
If you go into the shaping tab and click on * currently used * you might find out what morphs is affecting your characters.
Also, try the Parameter tab.
The problem is that this form is bound to these two parameters. If I turn them off, I will lose my original morph. It is possible that the "data" files are conflicting or mixed with these parameters. You need to somehow find them in the "data" folder itself and delete
Have you looked through the "Currently Used" list under the Parameters tab (with the character selected? That should list all of the active morphs, and may indicate the installed character or product that is causing the distortion.
I checked. And I found out that if you disable these two parameters, the form will become relatively normal, but I need these parameters. In addition, this distortion is present on other morphs and they do not use these parameters.
