GPU not really being used in renders....
I have the lastest driver and daz studio update but Ive notice that my GPU in not really being used. CPU in at 100%, Memory at 90%, GPU between 0-3%. Got a 3060ti GPU, i7-8700 CPU, and 32gb of memory. Please help and thanks in advance
  • With 100% CPU use it does sound unlikely that the GPU is being used (assuming you don't have CPU enabled in the Advanced tab of Render Settings) but how are you getting those stats? Windiows Task Manager's process list is not helpful.
    What are your exact versions for DS (Help>ABout Daz Studio) and nVidia driver (right-click on desktop>nVidia Control Panel)?
  • Im using nVidia studio driver 460.89 and Daz studio 4.14.0.10 Pro. Got my stats from the task manager under the performance tab. I had the CPU box checked but now its unchecked and it seems to still be using 100% of the CPU. Its using my 3060ti a bit more but not at 100%. FYI Im using 2 GPU, the other one is a 1060
  • If you do a render, then go to Help>Troubleshooting>View Log File then the very end should give details of which devices were used in rendering.
  • Ok so I just finished a render and this was my log at the end...
    2020-12-21 17:57:27.950 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:
    2020-12-21 17:57:27.958 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (GeForce RTX 3060 Ti): 696 iterations, 4.779s init, 9999.719s render
    2020-12-21 17:57:27.958 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 1 (GeForce GTX 1060 6GB): 0 iterations, 0.719s init, 0.000s render
  • So it looks as if the 3060Ti is being used but the 1060 is dropping out - probably not surprising as its 6GB of RAM will be loaded with a chunk of RTX-emulating code, which the 3060Ti doesn't need.
  • Ok now that Im trying to render, I get the blank black render...
  • 2020-12-21 20:32:20.457 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: No device specified or usable
    2020-12-21 20:32:20.461 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 0 device(s):
    2020-12-21 20:32:20.461 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2020-12-21 20:32:20.461 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: No worker to render with: aborting render
    2020-12-21 20:32:20.461 Iray Render error: Internal rendering error.
    There are the errors I got sad
    I have the exact same version of DAZ + nvidia drivers on a rtx 3090 and I'm experiencing no problems whatsoever. Maybye try to do a clean driver install? Re-download the lastes drivers, and upon installing them choose "Advanced options" and check "perform a clean install".  Remember that your GPU has 8GB of memory in total, but due to IRAY needing some additional memory for it's internal stuff you'll get ~6.8GB of "real", usable memory. If you your scene exceeds that, it will drop the render to CPU.
  • Ive reinstalled nVidia driver and still same issues. Gave me the same error codes as before. I even tried to render in the public build beta but just get black screen render sad Honestly very annoyed at this point.
    Try removing the GTX 1060
  • Removed my 1060 gpu. It seem to work for one render but after that, just black render screens. Decided to have my CPU and my 3060ti split the render load. Until I get another GPU Im going to leave it like that
    DARN! Turns out you may not be doing anything wrong! Got the same bloody problem today! I was using a custom batch rendering script which worked like a charm in DAZ 4.11 and 4.12. around 20 scenes to render, 10 of them rendered, others came out black, despite having tons of VRAM available (RTX 3090, top usage with these scenes were ~11GB VRAM), Iray just dropped to CPU and didn't render anything...
    2020-12-24 10:17:36.090 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [WARNING] - POST:RENDER ::   1.0   POST   rend warn : denoiser is not available on CPU and will be disabled.
    2020-12-24 10:17:36.090 Iray [INFO] - POST:RENDER ::   1.0   POST   rend info : Postprocessing denoiser is enabled
    2020-12-24 10:17:36.091 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry.
    2020-12-24 10:17:36.091 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating motion transforms.
    2020-12-24 10:17:36.091 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing scene graph.
    2020-12-24 10:17:36.091 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing geometry for motion time 0
    2020-12-24 10:17:36.292 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Geometry import (1 triangle object with 671k triangles, 0 fiber objects with 0 fibers (0 segments), 1 triangle instance yielding 671k triangles, 0 fiber instances yielding 0 segments) took 0.200s
    2020-12-24 10:17:36.294 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating materials.
    2020-12-24 10:17:36.310 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : found 259 textures, 0 lambdas (0 unique)
    2020-12-24 10:17:36.315 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Emitter geometry import (7 light sources with 52700 triangles, 1 instance) took 0.001s
    2020-12-24 10:17:36.315 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment.
    2020-12-24 10:17:36.406 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate.
    2020-12-24 10:17:36.409 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lens.
    2020-12-24 10:17:36.409 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.
    2020-12-24 10:17:36.409 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.
    2020-12-24 10:17:36.409 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating caustic portals.
    2020-12-24 10:17:36.409 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.
    2020-12-24 10:17:36.438 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using iray core convergence estimate.
    2020-12-24 10:17:36.441 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
    2020-12-24 10:17:36.473 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using batch scheduling, caustic sampler disabled
    2020-12-24 10:17:36.473 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing local rendering.
    2020-12-24 10:17:36.481 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: No device specified or usable
    2020-12-24 10:17:36.482 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 0 device(s):
    2020-12-24 10:17:36.482 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2020-12-24 10:17:36.482 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: No worker to render with: aborting render
    2020-12-24 10:17:36.482 Iray Render error: Internal rendering error.
    Is this an IRAY issue, or perhaps a driver issue? I'm using Studio Driver 460.89
    OK, I have figured something out - Are you using Iray Section Planes? If yes, try to delete it from the scene, save the scene, close/open DAZ and re-render. Worked for me... not really a solution, but at least I know the source of the problem.
  • How do you delete the Iray section planes?
  • Wait my scene doesnt have a Iray section plane.....indecision
    Pull out your GPU and make sure it's seated properly when you put it back in.
  • cav8001cav8001 Posts: 0
    I found a solution to this problem that worked for me. In windows 10, go to SETTINGS and type "graphics settings." Now, turn Hardware accelerated GPU scheduling ON. Inside DAZ Studio, make sure to uncheck CPU in both devices boxes in the advanced tab. Also, uncheck "allow CPU fallback" at the bottom.
