Dforce simulation weight map not working
So I am trying to add dforce to this hair.   I've done this with anotehr hair before but for some reason I can't figure out what I am doing wrong this time.  As you can see I added the dforce modifier weight node, selected the parts I want to edit with the geometry editor and have selected the weight node brush tool.  However when I go to add the weight map it is blank and the drop down won't let me do anything.  Anyone know what is going on?
  • SevrinSevrin Posts: 6,313
    Step 1: Add dForce Dynamic Modifier to mesh
    Step 2: Create dForce Modifier Weight Node.
    Step 3: Add Map
    It looks like the dForce modifier hasn't been added to the mesh, or wasn't added before creating the weight node.  The Riley hair does not come with a dForce modifier applied, so you have to do that yourself.
    559 x 395 - 38K
  • Thnaks.  I did forget the dforce modifier.
