Content libary snafu
Lonnie DudeLonnie Dude Posts: 51
The first pane in the content library which lists; DAZ Studio formats, Poser Formats, other formats, then Products and categories, my products and categories are missing from that first pane. Also, is there a link that describes the functions in the content database maintenance window?
  • fixmypcmikefixmypcmike Posts: 19,710
    If Products and Categories aren't shoeing then either PostgreSQL isn't running, or it's being blocked from communicating with DS. Does Task Manager show about 7 instances of postgres.exe?
  • Richard HaseltineRichard Haseltine Posts: 109,603
    As an aside, you shouldn't have that Content folder in the third column - the files and folders in that should be in the My DAZ 3D Library folder or geometry and textures will not be found.
    edited June 2014
    If you click on the ? icon at the bottom of the window, then click on the item you wish to know more about.
    You can also see these options if you have Tool Tips switched on.
    Post edited by JimmyC_2009 on
  • Lonnie DudeLonnie Dude Posts: 51
    Task manager doesn't show the Postgre SQL running at all. I guess that's the problem
  • JaderailJaderail Posts: 0
    And as Richard points out the Content Folder inside the My Library folder is a Nested Content folder. That alone will cause database errors as the paths do not read properly in DAZ Studio if at all. It needs all its folders Merged with your Main My Library folder and that Content folder removed.
