tonemapper and environment scene elements when deleting a new scene
StratDragon
is there any way to not have them created, I don't use them and apparently if you load a new scene at startup and they are there by default there appears to be a noticeable deletion process before you can load the new scene.
If you delete them you will reset the values of the relevant properties to their defaults - is that what you want?
I guess. It may expalin why clicking the default button in the render tab doesn't change anything since I upgraded to 4.14
