Shader Mixer Tutorial
darkdronerdarkdroner Posts: 20
Hi - I'm confused yet again...I downloaded the free Shadow Mixer Tutorial which is a PDF tutorial. Does anyone know how I access this PDF tutorial?? I can find the relevant files in my content library and I checked the interactive lesson area at the bottom of the screen but no luck there. Any suggestions on where I should look would be greatly appreciated. Thank you.
    edited June 2014
    You wont see PDF files inside DAZ Studio.
    You will need Adobe Acrobat reader, or some other way of reading a PDF document. DIM installed the PDF document into :
    C:\Users\Public\Documents\My DAZ 3D Library\ReadMe's and it is called 11676_Shader_Mixer_Tutorial.PDF.
    EDIT:
    Anything you install with DIM is listed in the Installed tab, Find the item, right click, and select Show Installed Files, this will give a clickable link to where the files are installed to.
    Post edited by JimmyC_2009 on
  • darkdronerdarkdroner Posts: 20
    Thank you so much for the advice - I've now found the pdf document. I love this forum - I always get great advice minutes after posting. Cheers!
    It's a pleasure!
