Chopped nose tip Genesis 8 Female
Hello to Everyone,
Please help me guys, I noticed that there is something wrong with the base genesis 8 female model... look at her nose, why is the tip of the nose "broken"
Does somebody has any idea why is it so? The other base models nose are normal... I am using DAZ 4.14.
Thanks in advance.
That looks as if a morph is applying on load - the base shape certainlky isn't like that. Go to the Parameters pane and click in the Currently Used group - are any of the properties listed there causing the shape? If not try Edit>Figure>Zero>Zero Figure - are there now properties showing in Currently Used that, when turned up, cause the nose shape?
Thank you Sir, it's working as you described :)
