Michael 6 and a floating eyelash
nemesis10nemesis10 Posts: 3,895
I was trying out the new morph set from Shimuzu and noticed that Michael 6's lower eyelash seems to float. Does anyone have suggestions?
    if you can confirm the morph cause the effect,
    and already detect the morph name which eye lush floating,
    and you do not wait vendor up-date, (sometimes,, it take long time I beleive,, )
    you need manually make adjustment morph, in other modelor.
    or overwrite generated morph..^^;
    (it is a little sensitive work , but not so difficult, to adjust eye lush positon correctly to current eyelids shape.:)
    then export good sahpe as morph, then overwrite problem morph.
    or just make delta morph from current bad sahpe, and manually apply it,,)
    then I do not have the product, but in the product pic, all character seems keep good eye lush positon,,:roll:
    Then if the product cause such effect, you may better send porduct bug report.
    to show what caused the bad effect about eye rush ,
    you may better, remove all map from eye lash,
    then color eyelush diffuse red (etc) with half opacity.
    and show pic of daz 3d view port, with currently used morph setting.(you may need only apply the problem morhp,
    then checked it )
    Because,, I think,, without these pic, usually support teams, can not find what cause the problem clear.:roll:
    946 x 563 - 119K
  • nemesis10nemesis10 Posts: 3,895
    I think I have narrowed the problem down to an errant displacement map applied to the eyelash... by "borrowing" the settings from another figure, i fixed the problem.
