D3D DSON imports full body morph on default genesis
WendyLuvsCatz
for some bizarre reason the D3D DSON importer imports a full body morph dialed on default genesis,
is all fine in Daz studio.
I created a Jaderail morph from Genesis2male that I transferred over using GenX and it is dialed to 1 in Poser.
my other morphs are not inc GenX ones so what is different about this one?
I used morphloader to do the full body morph from Jaderails spun dialed parameter presets exported as an obj so I could genX it over unlike most others so is that why?
I can fix it resetting the dial to zero in Poser
Try clearing both the DSON Cache through DS (Edit > Prefs), and delete the files pertaining to G2M in your library\runtime\dson\auto_adapted folder.
I tend to remove that entire auto_adapted folder and clear the dson cache time to time, otherwise I get some pretty wonky stuff happening (including full on Poser crashes).
Clearing Poser's temp files wouldn't be a bad idea, either.
thx will try
