Why is there no good lip sync solution for Genesis 8?
Daz has made a lot of improvements to its animation capabilities in the last year or so, but you really can't do quality character animation without decent lip sync. There hasn't been a decent solution since Mimic Pro, over a decade ago. Will we ever get good lip sync for Genesis 8? I'd like to move on from V4/M4!
  • wolf359wolf359 Posts: 3,936
    Anilip 2??? Make your own judgement
    about its price verses performance.
    The Face mojo software is an excellent option for Iphone owners or those who are willing to buy an Iphone
    (used Iphone 11 perhaps??)
    That is the state of things for G8
  • Face Mojo is pretty impressive in its ability to animate expressions, but I can't say that the lip sync looks terribly precise in the samples on their site--they look a bit stiff, and there are limited tongue movements. It also wouldn't be terribly useful for pre-recorded and edited voice tracks, which is what most animators (and myself) work with. Anilip looks to have more range of movement in the mouth/lips, but is really not very accurate in their samples. To be fair, Mimic Pro didn't always do a great job with its initial "automatic" lip snyc, but it was really easy to edit the phonemes track after the initial import--the phonemes work a little like Aniblocks--and you can get pretty good results. It doesn't look like you can edit the phoneme track within the Anilip application in the same way, tho I can't be 100% sure from the info on their vendor page. It might help if we could see the video tutorials they mention on their site so we could see what the editing capabilities are like.
    edited December 2020
    With  several new Iphone/ARK kit, camera based facial mocap options
    seemingly appearing every year, the age of the audio based lipsynch systems may be sadly, coming to a close
    That said I dont/wont buy any apple luxury brand products
    The primary reason I moved away from the DAZ genesis ecosystem ,for primary CG actors, is because Reallusion still offers a powerful  built-in audio based system with lip smoothing and phoneme replacement  pallet along side of its optional Iphone based facial capture plugin.
    Creating the lip sync for"Galactus Rising" was a cumbersome chore
    of having to use the Zombie mimic pro 3 for my G2 and below figures and piping hard line audio in from a second computer to trick Daz mimic live into capturing my pre-recorded audio for G3 & above
    and then manually animating facial expressions on top of the lipsync .
    I remember reading about your "oversized eyes" issue requiring you to stick with a custom V4 Character in your current film project
    So I know it is frustating wanting to move on to modern assets.
    Frankly I actually had a different,more resolute ending planned for "Galactus Rising" But effectively "quit" the project at 92 minutes and rolled credits.
    This is because I was so tired & desperate to move on to my new streamlined ,Realtime Iclone/CC3/Blender based pipeline all with native program features and Zero third party dependencies for primary animation/lipsync and rendering.
    Even if you find the results from Anilip2 or FaceMojo acceptable
    they remain third party ,single point of failure, options that eventually may be broken by a DS update or a new genesis figure generation with no assurance that the third party vendors will be around/alive in the future to provide updates.
    1506 x 951 - 184K
    Post edited by wolf359 on
  • @Auroratrek
    What did you use for your Star Trek videos?
    @Auroratrek
    Mimic pro 3 a 16 year old "necro application" from Daz. that only works with Poser Cr2 based figures.
    1701 x 1012 - 138K
  • Yeesh.
  • There is a free software called Papagayo that I was able to use to do lip syncing.  I wrote a script that converts its output into a file that I can import into DAZ Studio.  Here is an animation I made using it on Genesis 8.
  • wolf359 said:
    ...I know it is frustating wanting to move on to modern assets.
    Very! It seems like everything I try runs into a road block (or "buts").
    MimicPro actyually works pretty well for editing phonemes right onto a sample Daz character, but doesn't work with G8.
    Papgayo works with G8, but you don't get to see a representation of the Daz model when you're editing the phonemes, or have a lot of control.
    Anilip works with G8, but it doesn't appear to have robust phoneme editing either.
    I'd be happy to try using the Face Control to animate the mouth movements manually, but as far as I know, you can't scrub audio or see the audio waveform in Daz.
    Face capture apps look interesting but I only used pre-recorded and edited dialogue.
    It's a real pain in the "but"!
  • Mimic Pro for Carrara works pretty well with Genesis 3 & 8 IMO
    And using Fenric's BVH exporter actually works in DAZ studio as apparently it only moves the bones!
    I have yet to get an iClone facial BVH to work but the Carrara one does on facial as well as body bones, Carrara does enjoy a closer compatibility with DAZ studio in that respect as DAZ collada exports of DAZ/Poser content largely works in DAZ studio too as does with some issues Carrara rigging unlike other software.
    Mimic live works with G8..BUT..the only way to use pre-recorded audio is to pipe it in from a second computer sound card (via a two
    headed 16 mm audio cable.)
    And there is only a global strength adjustment
    and no phoneme replacement/editing or live scrubbing &audio wave form  Display in Daz studio.
    And with due respect to Carrara loyalists,  Carrara,Like  Mimic pro 3, is more vestigial Daz,necro-ware at a development dead end, which defeats the whole purpose of trying to move on to modern solutions.
    These are the exact reasons why I moved to a different Character Eco system with unified set of audio based ,modern lipsync&facial animation tools.
    So, any chance one could use Mimic Pro for Carrara on a G8 character and export/save just the lip sync animation to Daz Studio, or is that another "but"? (And it doesn't look like G8 works natively in Carrara?)
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,288
    you need the character solution Misty has at Renderosity that has had the strangely spelt node names on some bones edited and Blended weight applied.
    Its the mismatch in node names that crashes Carrara and Blended weight adds triax which C8.5 can use.
    in Carrara you need Fenric's  BVH exporter he has made available for free as well as Carrara Mimic pro.
    Unfortunately a recent buyer has not been able to get a serial number from DAZ so this is not a good time to buy stuff they don't want to support.
    https://www.renderosity.com/rr/mod/freestuff/?item_id=77504
    https://www.renderosity.com/rr/mod/freestuff/carrara-compatible-character-preset-for-genesis-8-male/77745
  • SevrinSevrin Posts: 6,313
    It would have been nice to have more of a close-up, but that looks really, really good.   To my eye, it's better than what I've seen from Facemojo.
    A BVH file exported from Carrara/Fenric cannot carry facial viseme morphs and trying to import only the G8 face rig animation will
    still miss alot of important facial movements
    The free Daz script to use the papagayo utility output can yeild decent base layer results (after some initial set up) and if you are willing to hand key facial expressions on top of the lipsync
    it is obviously the cheapest Audio based solution for G3/G8 (Free)
    Also the papagayo interface has a huge audio waveform display
    for you to line up your speech text and real time scrubbing
    with the little proxy mouth in the upper right corner that plays the lipsync in realtime.
    1636 x 860 - 264K
  • nonesuch00nonesuch00 Posts: 18,773
    Where is this free DAZ script to use Papagayo?
  • Looks like Renderosity has the scirpt. I might give it a try. I mean, the price is right! ;-)
    https://www.renderosity.com/rr/mod/freestuff/?item_id=77470
    https://www.mohoanimation.com/papagayo.shtml
    --Tim
    --Tim
    Thanks
    I was correct: the price is right. Back to V4.
    If you are sticking with V4 for animation in DS  and have not updated to DS 4.14 some people have reported some problems with the Mill 4 generation in 4.14  in this thread.
    https://www.daz3d.com/forums/discussion/459596/support-for-gen4-in-ds-4-14#latest
  • AuroratrekAuroratrek Posts: 257
    Okay, so I buckled down and gave the iClone lip sync another try, and I have to say I am pleasantly surprised by the results. The trick (for me) was to just delete the automatically-generated phonemes and just add them manually. The auto-generated phonemes were mostly garbage--it's more work to fix them than to start from scratch.
    Wolf, I was able to solve the "oversize eyes" issue by converting to CC3+ and use "fix eye close" function.
    V4 brought into iClone (along with a bit of Shakespeare):
    Post edited by Auroratrek on
    Excellent!! Glad you found a solution Tim.
    Now at least you have the option of moving up to G8 figures Via
    CC3 conversion.
    You can even Alembic export from IC 7 to C4D .
  • Thanks, Wolf! Yes, opens up a lot of new possibilities. The FBX from IC 7 is actually pretty good, but so far I can't get "Look at" to work on an FBX figure in C4D, so Alembic might be the only way to do it right now.
  • DobitDobit Posts: 207
    I just saw the discussion and wanted to contribute something as a manufacturer of Anilip2. We use 2 different technologies to generate phonemes / visemes.
    • On the one hand, we use synthetic voices, for which a relatively exact identification of the phonemes is possible, if the manufacturer of these voices offers appropriate interfaces (e.g. Windows SAPI).
    • On the other hand, we work with speech recognition. Here the conversion to Visemes is much more difficult and depends on the quality of the speech recognition.
    • Thirdly, the conversion of phonemes to visemes is not one-to-one. There are so-called co-articulation rules that influence the generation of visemes.
    Because the automatic generation of visemes is anything but trivial, we have a very sophisticated viseme editor in Anilip 2, where many aspects of the viseme animation can be adjusted. If you like, you can take a look at some aspects of the editor here in the tutorial.
    The Anilip 2 community is growing and we are accordingly taking care of the further development. For existing customers we just put an big update 2.1 online today.
    We believe synthetic voices and automatic lip animation are the future. Mocap solutions (we are working on them ourselves. see aniHead) always require some hardware and sometimes  an (sometimes expensive) actor. We are therefore continuing and already develop on a new version of Anilip
    The requirements for lip animation are very different, but we believe Anilip 2 is a good solution for most needs.
  • DarthDDarthD Posts: 259
    Based on the the advertisement video for Anilip2...lets just say I'm less than impressed. Why won't Daz update Lip Sync? It seems to work better than anything else I've seen so far. Here is a clip from a movie I've been working on, using LipSinc and Genesis 2. https://youtu.be/OGICfr8hhzc
