Renaming a surface - SOLVED
Hera
I've been trying to figure out how to remain a surface - is that even possible? (I have an object where all the surfaces have only numbers, and it's more or less impossible to tell which one is which)
Post edited by Hera on
Go to tools -> geometry editor then window -> panes -> tool settings
in the tool settings tab you can double click a surface name and it will let you edit it :)
Thanks!!
