How do I prepare v4/m4 skin mats for use on G2 M/F?
Ademnus
How do I get them onto g2?
Ademnus
Select th model in Scene tab? Select the model in Surface tab as well, and then add the texture from your library an then, Select M4 or V4 from the UV tab selections in Surfaces and it should go on.
Apply the textures to V4/M4 or to Genesis (the advantage of using M4 or V4 is that they have the eye surface materials, which Genesis lacks and so will lose settings for) then go to File>Save as>Materials Preset.
One way would be to perform a manual process (I wrote a simple guide, available at ShareCG and deviantART) or you can use the script available here, by DraagonStorm
Or the free script here by Dimension3D http://d3d.sesseler.de/index.php?software=dazscript&product=gen4g2mat
It creates a copy of the materials, prepended with G2_. Has batch convert abilities, but not subfolder. Does not require conversion to DUF.
You'll still need the V4 for G2F and/or M4 for G2M products to get the UVs.
http://www.daz3d.com/victoria-4-for-genesis-2-female
http://www.daz3d.com/michael-4-for-genesis-2-male
