Won't load morphs.
I have a set of morphs that I transferred from Genesis 3 to Genesis 8. The morphs are located in the correct location (D:\Users\Documents\My DAZ 3D Library\data\DAZ 3D\Genesis 8\Female\Morphs\Designem\Natural Morphs\ morphname.dsf...) but they don't load when I pick the Gen 8 character.
The morphs on Gen 8 worked when I did the transfer utility. I saved them as a morph asset. So I can't see why they aren't loading..
Can someone help?
How did you transfer them?
using the transfer utility dialog box
Interestingly enough. I did the same procedure using the transfer utility dialog box to transfer the morphs onto Gen 8 then did Save as support asset/ morph asset. I picked the morphs to save and this time it stuck. So we can call this post closed.
I guess if at first you don't suceed then do exactly the same thing until it works..Ha
