Trouble locating content yet again.....
Hi again - this time I can't find my Eastern Dragon Poses content. Damned if I know why I'm having so many problems locating content that I download via DIM. I've confirmed that the content is indeed on my computer in my 'My DAZ 3D Library' folder. I've attached screendshots which confirm I installed Eastern Dragon & Eastern Dragon Poses & also a shot of my poses area of DAZ confirming that not a pose is to be seen anywhere. Can anyone offer this noob some advice on what I should be doing to access this content? Many thanks.
Post edited by darkdroner on
The Eastern Dragon Poses are in Poser format (PZ2)
You will find them in the Content Library under Poser Formats > My DAZ 3D Library > Pose. To find exactly what has been installed, and to where, right click on the file in the Installed tab in DIM, and select Show Installed Files.
The list that comes up in DIM are clickable links directly to your files, but you should be able to find them using the instructions above. I cannot help with the setup you are using, I have never used that, and I only use the Content Library pane.
