anyone know how I can remove these strange side bumps on my G8F?
In the picture to the left and right of her belly button each side it sort of juts out unnatually. I have played around with the waist/hips/stomach settings but nothing seems to help remove them. Anyone know what I can do? thankyou.
  • BeeMKayBeeMKay Posts: 7,019
    edited December 2020
    That's her hip bone, which seems to be very visible... does it also show up like this in your render? If not, it is probably just an artifact of the preview screen.
    Post edited by BeeMKay on
  • NylonGirlNylonGirl Posts: 2,293
    I don't know if they will fix your problem but if you have the female body morphs
    https://www.daz3d.com/genesis-8-female-body-morphs
    Then maybe adjusting one of these sliders will help:
    Hip Bone Crest
    Hip Bone Size
  • DrekkanDrekkan Posts: 460
    *sigh* no nothing seems to make much of a difference its a real pain in the *** because now I have to restart the entire character.
    Don't suppose there is a way for someone to edit this for me at all if they already have the female body morphs? if that's allowed here because I'm struggling to fix it.
    Post edited by Drekkan on
  • nabob21nabob21 Posts: 1,057
    You have probably tried all of this but if not, here is what I have done when I have similar problems:
    1. Save a copy of the character so that you don't loose anything.
    2. Click on "currently used" and one by one turn off the morphs that are active. This can help identify the morph that is misbehaving. Do this one by one so that you can see which morph is the problem.
    3. If you remember what the settings where on the morphs that you have turned off, turn all of them back on except for the one that was causing the issue. See if the problem re-occurs.
    4. If you don't remember the settings for the morphs that you turned off, close the scene and open a new scene with the copy of the character that you saved in step #1. Turn off the problem morph that you identified in Step #2 and see if the issue is resolved.
    If more than one morph is involved you may have to repeat the process multiple times.
    Post edited by nabob21 on
    I was able to sort it using nabob21's method. Thanks to them and all who tried to help.
