mcjSizer - Script to view and modify the size of objects - for Daz Studio 1, 2, 3, 4
mCasualmCasual Posts: 4,607
edited June 2014 in Freebies
download here : https://sites.google.com/site/mcasualsdazscripts4/mcjsizer
example :
you imported a door-unit in a Daz Studio scene
you resized it best as you could so it fits the hole in the wall
you know for sure that this hole is 500 x 750 cm
you select the door-unit
run the script
you see that the door unit is presently
500.25 x 749.22 x 21.75 centimeters
so you type
500, 750, 20
click the "resize button"
and bam it's done perfect fits puttin on the ritz
Post edited by mCasual on
  • KalisxKalisx Posts: 112
    Very useful.
    Many THANHX for this share.
  • MorganRLewisMorganRLewis Posts: 233
    That will be quite handy. Thank you.
  • StratDragonStratDragon Posts: 3,275
    Is this for measurements in "cm" only? We Americans are baffled by the metric systems as you know, I'm still trying to convert liters to hectometers.
  • mCasualmCasual Posts: 4,607
    edited June 2014
    yes it's in cm
    i thought that since Dat Studio's translate sliders are in centimeters, that users were somewhat getting used to it
    but but but i'll add a cm / inches option today
    ( initially this was a script i wrote quickly for my door-fitting needs )
    i'll use the opportunity to introduce a feature i regreted not including :
    when we run the script we discover Aiko3 is 68 inches tall
    if i want to make her 67 inches i type Y (height) = 67
    in the upcoming version if i type X = -1 and Z = -1
    the script will compute the values for X (width) and Z (depth) that won't modify Aiko3's ratios
    1920 x 1080 - 1M
    943 x 668 - 419K
    1920 x 1080 - 560K
    1920 x 1080 - 508K
    edited June 2014
    ** UPDATE ** UPDATE ** UPDATE ** UPDATE ** UPDATE ** UPDATE ** UPDATE **
    Units
    As of version 2 you can specify if you are working in centimeters or in inches
    Proportional resizing
    If two of the three dimensions are set to the value -1, mcjSizer will perform proportional resizing based on the dimension which is not set to -1
    for example, X: -1 , Y : 72, Z:-1 will resize a figure to 72 units tall
    1920 x 1080 - 2M
