Texture in Valandar's computer is upside-down (solved)
starionwolfstarionwolf Posts: 3,670
Textures that I apply to computer desk always appear upside down.
Go to surfaces tab.
Select monitor's screen surface.
Select texture from texture control.
Expected result: load texture right-side up.
Actual result: texture that is loaded is upside-down
I tried rotating the image in Gimp and then loading the new image that is upside-down.
I couldn't find any option to rotate or flip the image in Daz Studio 4. I'm stumped. How do I make the texture appear right-side up?
Post edited by starionwolf on
    Go to the Diffuse tab in the Surfaces pane.
    Click on your image (small icon), and select Layered Image Editor from the drop down. Once in there, use the Rotate 180 degrees option, that should fix it.
  • Richard HaseltineRichard Haseltine Posts: 109,267
    You could also, in the Surfaces pane, set Horizontal tiles and Vertical tiles to -1.
    Thanks Richard, never thought of that one :)
  • starionwolfstarionwolf Posts: 3,670
    Thanks, I solved the issue. Bye
    384 x 347 - 36K
