DS 4.14.0.8 .. Right side pane column overlaps main viewport if pulled over too far.
Lissa_xyzLissa_xyz Posts: 6,116
Anyone else have this issue? It's driving me nuts. I don't have this problem with the left side. Freshly wiped/re-installed everything Daz yesterday as I'd been away for a couple years (program files, libraries, appdata, the works).
Post edited by Lissa_xyz on
  • fixmypcmikefixmypcmike Posts: 19,702
    See if you have other panes docked in the center with the viewport, and close them
  • Most likely Shader Mixer/Shader Builder
    edited December 2020
    I did indeed have that (I didn't think to see if that was still an issue). Moved it to an upper/lower dock and all's well. Thanks guys!
    1015 x 964 - 273K
